Hi everyone,
I cannot upload one of my CTT receivers in R and I am running out of options to access data using Motus R Book.
After following your typical Motus R Book guidelines to upload packages and setting your directory, I encounter an issue when running:
proj.num ← “CTT-5031194D3168” # IndianRidge3-MPG-MT
sql.motus ← tagme(proj.num, new = F, forceMeta = TRUE, update=TRUE)
What happens is that the very first batch ID (e.g. #1 of 1979) seems to run forever and never goes to the next batch ID (e.g., #2 of 1979).
Any idea on the cause of this issue?
Josh at Motus HQ had issues with this receiver a while back when trying to help me but it now works for him. I wonder if it is a computer compatibility problem as I am a Mac user (MacOS Catalina - Version 10.15.7).
I would appreciate any advice on this. I could try changing laptops to troubleshoot but ultimately want/need to use this particular laptop for future operations.
The same issue happens if I run the code without forcing metadata or forcing an update, or after deleting my receiver files and starting from scratch, or after uninstalling and then re-installing all my R packages.
Thanks for any feedback,
William Blake
IWC Motus Project #213 & #226
