As an individual, I have built an RPI Sensorgnome (SG).
https://motus.org/data/receiverDeployment?id=8928
It appears to be collecting data from it’s four antenna. I configured it to connect to my LAN and I can connect to it with SSH and a browser. It provides its own LAN when the push button switch is pressed twice and I can connect to it by joining its LAN.
It has failed to connect to Motus using my LAN. Hoping it is relevant, here is a segment of syslog from the SG.
Aug 15 14:25:01 localhost CRON[14148]: (root) CMD ( /home/bone/proj/bonedongle/scripts/maintain_ssh_tunnel)
Aug 15 14:29:43 localhost autossh[624]: starting ssh (count 179)
Aug 15 14:29:43 localhost autossh[624]: ssh child pid is 14167
Aug 15 14:29:43 localhost rsyslogd-2007: action ‘action 17’ suspended, next retry is Mon Aug 15 14:31:13 2022 [try You searched for error 2007 - rsyslog ]
Aug 15 14:29:43 localhost autossh[624]: ssh exited with error status 255; restarting ssh
At one point, the syslog showed a message indicating that my desktop Mac rejected a SG request.
Aug 15 08:46:41 localhost avahi-daemon[592]: Received response from host 192.168.0.64 with invalid source port 52214 on interface ‘wlan0.0’
I removed all servers from the LAN and allowed the SG to run ‘alone’ on the LAN and I haven’t seen the 192.168.0.64 since but connecting to Motus still fails.
I am not sure how to proceed. I assume that the RPi SG can connect to Motus over the internet. I ask because the cron task maintain_ssh_tunnel is from /home/bone/… instead of /home/pi/… (they are the same shell).
Any help would be appreciated .
Gene Dodd
