Hello Motus collaborators,
We have an important message/ reminder regarding data processing for SensorGnomes following a fresh installation of the SG software.
As many of you will know, SensorGnomes record an incremental boot number in the name of detection data files. This boot number is used during data processing to correct for bad GPS timestamps and to link together long detection runs that are spread across multiple data uploads.
Given this, there is an assumption made during data processing that the boot number will always be incremental. In nearly every case, this is true, with the exception of when completely fresh software is installed on an SG. A fresh installation will reset the boot count to zero and, since that will then violate the assumption that the boot number will always increment, can lead to missing or false detections in some cases.
For Raspberry Pi SensorGnomes running V2 Software
If running the V2 SensorGnome software, you can manually update the boot number following a software upgrade. That option is available on the “software” tab of the web interface. There is more info on this here: Software upgrade | SensorGnome User Guide
If you are running version 2024-XXX or later, and are upgrading the software over the internet, the boot number will be correctly incremented automatically. [SG versions 2023-XXX and earlier require an extra step.
For all other SensorGnomes
If you cannot, or would prefer not to, run the V2 SensorGnome software, there is currently no method of updating the boot number following a clean installation of the SG software. However, see below regarding reruns/ reprocessing.
In ALL cases
When a receiver’s data is reprocessed (also referred to as re-running), the correct boot number sequence is restored and any spurious or missing detections resolved – assuming all tag deployment metadata is up-to-date.
There is more information about receiver data reprocessing here: Reprocessing receiver data | Motus Docs
