Tag Database file upload fail
We recently replaced our v3.2 SensorStations with v3.3 units because of the lower background noise produced by the newer version. However, we are now encountering an issue when trying to upload the tag database.
The SensorStation interface on the PC does not allow us to upload the tag database. Has anyone experienced this issue before, or is there another way to upload the tag database to the SensorStation?
Any suggestions would be greatly appreciated.
Thanks in advance for your help!
Kind regards,
Jitse Creemers
Hi Jitse, have you tried uploading the .sqlite file instead? I think the .csv format used to be supported, but I don’t think it is anymore. The sqlite tag database for your project can be downloaded here: Motus Wildlife Tracking System.
I have encountered the exact same issue multiple times. I suspect it may be caused by the database file being corrupted during transfer to the sensorstation - perhaps because of the existing of the prior database file you are trying to overwrite being in use by the station. Although I have not conclusively verified that, I do seem to get more reliable results if there is no pre-existing /data/sg_files/sg_tag_database.sqlite file on the RPi.. What I have done is written up a procedure that seems to work reliably for me. Its not guaranteed but it may be worth a shot. See below.
Loading your Lotek tag database to a CTT SensorStation
----- STEP 1 ----- Get your tag database from Motus.org > Manage Tags
  • Usually lands as a timestamped .sqlite file in “Downloads” folder
  • Rename the file to SG_tag_database.sqlite
  • I assume below it will be found in “Downloads”
----- STEP 2 ----- Obtain your SensorStation’s Network IP number from the LCD display at “Network” > “IP Number” (it can be either wlan0 or eth0 but the station and your laptop must be on the same network)
In this example my stations IP number is 10.0.0.130
----- STEP 3 ----- Move (or delete) the current current tag database on the SensorStation using ssh and linux commands. ** This step is critical **
These instructions will perform the following actions:
  • login via ssh from your computer
  • locate the current tag database
  • rename it and then exit the ssh session
open a new terminal window on your laptop/computer: (cmd.exe or Putty for windows or iTerm for Macs)
ssh ctt@10.0.0.130 <<< substitute your IP number here
(enter the ctt pswd - typically ctt-station, ctt-sensor or raspberry )
cd /data/sg_files
sudo mv SG_tag_database.sqlite ./SG_tag_database.sqlite.ORIGINAL (reenter ctt pswd: ctt-station if asked)
Leave this window open we will use it again in a moment
------ STEP 4 ------
Perform the actual copy the tag database file from your laptop/computer to the SensorStation:
From a second terminal cmd window on your laptop/computer: (We want to execute commands on the local laptop/computer)
Navigate to wherever the new SG_tag_database.sqlite file is located (using Mac/linux or Windows file separators)
cd ~/Downloads …or for windows… cd ~\Downloads
The following command copies the file to the SensorStation (Use eithr YOUR SensorStation IP number or hostname sensorstation.local)
scp ./SG_tag_database.sqlite ctt@sensorstation.local:/data/sg_files
OR (if hostname “sensorstation.local” is not recognized on your network ):
scp ./SG_tag_database.sqlite ctt@10.0.0.130:/data/sg_files
------ STEP 5 ------
Verify the transferred file was correctly copied using the terminal window that is Logged in to the Sensorstation
(If you should still be in /data/sg_files from Step 2)
Type command: sqlite3 SG_tag_database.sqlite ‘select * from tags’
You should see something similar to below showing your tags.
ctt@sensorstation:/data/sg_files $ sqlite3 SG_tag_database.sqlite ‘select * from tags’
580|534|166.380|166.376|26.852|151.352|156.234|10.8998003005981|-0.000300000014249235|0.0|0.0|0.00230940107675312|0.0|0.0|motus download|Lotek6M 580|48|166.380|166.376|31.733|39.059|63.468|38.2963981628418|-9.99999974737875e-05|0.00200000000000067|0.00200000000000244|0.0|0.0|0.0|motus download|Lotek6M 580|63|166.380|166.376|31.733|122.055|24.412|10.8994998931885|-9.99999974737875e-05|0.00200000000000067|0.00199999999999534|0.0|2.17558400799017e-15|0.0|motus download|Lotek6M
Restart the service: sudo systemctl restart sensorgnome
Refresh and check the sensor gnome webpage… does it see the changes?
reboot the SensorStation using the power ON/OFF switch
Verify with test tags through the Sensorgnome interface of the CTT Web interface.
FINALLY
I have encountered stubborn instances where the ‘select * from tags’ sqlite command succeeded but the final test of viewing through the sensor gnome web interface generated an error. I retried by repeating starting in Step 3 but actually deleting the SG_tag_database.sqlite file (since you had already preserved the original earlier.) After confirming the SG_tag_database.sqlite no longer exists. Proceed with the scp in Steps 4 and 5
ALTERNATE SUGGESTION THAT COMES TO MIND…
Simply removing the SG_tag_database.sqlite (directory:/data/sg_files) and then reboot and retry the SG web interface “Upload tag database” button may work as well ( Ive not verified). However my test procedure actually tests the database file is not corrupt to start with so seems more robust.
A side note to this post: There is no difference in how SensorStations filter / interpret background noise between V3.2 and 3.3. Replacing the receiver won’t reduce noise, that must be evaluated on the ground and can be mitigated via rotating Yagis away from noise source, or moving the station away from local noise
Thank you for your reply! Yes, I’ve tried uploading both the .sqlite file and the .csv file. First, I tried the .sqlite file since this is the format in which I downloaded the tag database from the Motus page in the first place. Given the “.csv” format in the error message, I’ve tried converting it to a .csv and uploading that format. But that didn’t work either.
Thank you! I will try this approach ASAP!
Hi, thank you for your reply! The problem was mostly the noise coming from the station itself. The electrical components from the board caused a lot of interference at the 150.1 MHz frequency our tags operate. We, as well as more experienced Motus users that came to help us, think that this caused our very limited detection range (only a couple of hundred meters) after which the tags were not detected above the noise floor anymore. We contacted CTT about this, and they have shielded these electrical components from the v3.3 boards with soldered iron ‘cages’. We want to perform some new range tests with our tags to see whether the detection range improved, but since I cannot upload the tag database, I haven’t been able to do this yet.
Kind regards
