Hi Scott,
We have had similar problems with sparrows. When we first put tags on birds (>15 years), entanglement was an issue and we quickly backed off from tagging. We followed up by surveying the research community and found that many others had had similar experiences, especially with birds that live in dense vegetation (for example, grassland sparrows, like those we were studying). Overall we found that about 1/3 of species reported on in the survey had had problems (but, not a random sample of species/studies!). We also found that very few people had documented these effects in the literature - often because, like us, they abandoned the study quickly and/or sample sizes were small so hard to publish.
A few years ago, we revisited telemetry, hoping that newer materials and improved methods might result in fewer problems. In our first pilot year, we were very judicious in our approach, but had no problems at all, so we decided to move ahead with the planned bigger study. In our second year, however, we saw the same entanglement problems even though we were using the same tags. It turned out that the antenna material had changed slightly between years, and that seemed to be the cause of the problem. We were able to make a switch back, and the problems went away again.
My take-homes are (a) seemingly very subtle differences in transmitter/antenna design can change outcomes, even within species/system, (b) we should be doing much more systematic reporting of problems even though it is often hard to do so, and (c) there are likely some clear patterns among species about where to expect problems, but they're hard to document because no individual research team has the necessary data.
Following our 2007 poll, we recommended the creation of an online repository of information on telemetry problems that would be collected systematically and allow for better information transfer among researchers, and periodic reviews using the crowdsourced data to look for patterns that no individual researcher could ever find. We got little traction, and because telemetry is not a major focus for our group (perhaps a poor excuse), we didn't do it ourselves. I wonder if the Motus network could be the way to make that happen?
Results of the survey we did are here:
Hill, JM, and CS Elphick. 2011. Are grassland passerines especially susceptible to negative transmitter impacts? Wildlife Society Bulletin 35:362-367.
Information about our more recent experiences will be in a forthcoming paper.
Chris
Chris Elphick
he/him/his
Ecology & Evolutionary Biology
University of Connecticut
http://elphick.lab.uconn.edu/
http://www.tidalmarshbirds.org/
http://ctbirdatlas.org/
https://entogem.github.io/
https://statusofinsects.github.io/
