Hello all.
This excerpt from a 2009 IEEE Antennas and Propagation article by Martin et al. (attached) is relevant to the electrically small antennas characteristic of nanotags (and other VHF telemetry):
"While it is generally straightforward to measure the efficiency
of a generic antenna, measurement of the present radiating
system with an electrically small monopole antenna is challenging.
The transmitter itself is extremely small, on the order of 1cm3 or
less. Therefore, without the bird present, the monopole has a
very small counterpoise, at best; with the transmitter mounted onto
the bird, the radiating system becomes more complex. In fact, the
lack of a large or well-defined ground plane in this case means that
both the body of the transmitter, as well as the bird, may serve as
parts of the counterpoise for the monopole."
This manuscript also describes a bird model for evaluating antennas.
Other antenna and telemetry experts have provided additional suggestions for bird models.
Beat Naef-Daenzer (Swiss Ornithological Institute) has used very simple models filled with Ringer-solution for medical use:
“For small “birds” the finger of a lab glove does very well, for larger
models, I use plastic bottles. Qualitatively, the shape of these bodies
does not matter much, while the mass is really important. Transmitters
can be fitted using the harness intended for attaching the radios to the
birds.”
I’ve also seen a suggestion from Kent Britain (http://wa5vjb.com/), although it’s not quite clear what volume of water to mix the sugar/salt into (I’ve sent a request for clarification):
“I suggest a small plastic bottle or plastic bag about 2/3rd the size of
the bird and fill it with water. Add about 10 spoons of sugar and 1 spoon of
salt. This will have the same Er and loss tangent as flesh.
Yes, it takes a while to get all that sugar to dissolve.
With a thick cloth to simulate the feathers, you can tune the antenna on
a simulated bird.”
Best,
2009_Martin-Methodology for efficiency measurements for antennas on birds.pdf (4.86 MB)
