Sensorgnome V2 software RC13
Release candidate 13 for the Sensorgnome V2 software has arrived!
I’m hoping that this is the last release candidate but who knows…
Fixes and improvements in this release:
  • update to latest version of Raspberry Pi OS ‘bullseye’ (2023-12-05) and updated packages
  • add some troubleshooting code for the Adafruit GPS (it’s not working on some SGs and we don’t know whether it’s a software issue or power issue)
  • monitor the rate at which the FUNcubes are producing data and alert if that changes/drops
  • keep system logs for 60-120 days to facilitate troubleshooting SDcards recovered from non-connected SGs
  • report cellular info into sg-hub-agent so it can be monitored on sghub
  • new repository key expiration
    Download: https://sensorgnome.s3.amazonaws.com/images/sg-armv7-rpi-2.0-rc13.zip
Documentation: https://docs.motus.org/sensorgnome-v2/
RaspberryPi Imager: https://www.raspberrypi.com/software/
Please connect your Sensorgnome to the Internet (ethernet, wifi, or cellular): it provides a wealth of monitoring data and makes troubleshooting and helping you sooo much easier!
Upgrading: as mentioned in my previous email, I made the rookie mistake to choose too short a repository signing key expiration period and let the key expire. The result is that existing V2 sensorgnomes cannot be upgraded by just clicking a button. Instead, you have to SSH in and run the following command (all one line), after that the upgrade button in the Web UI will work as usual:
sudo curl -L -o /etc/apt/trusted.gpg.d/sensorgnome.gpg https://sensorgnome.s3.amazonaws.com/sensorgnome.gpg
As usual, please don’t hesitate to contact me if you encounter issues, need help, or simply have a question.
Thanks much!
Thorsten von Eicken
