Hi folks,
Some people have been approached by David Winkler's group at Cornell
asking whether they can piggy-back a receiver for their solar-powered
tags onto a sensorgnome site.
This is now possible: one or more Cornell Tag XCVR USB radio dongles
can be plugged into spare USB ports on a sensorgnome, and detections
of Cornell coded tags will be recorded in the usual sensorgnome data
files. The XCVR dongle draws little additional power, so should not
affect SG operation.
This is good news. I do have one question. My impression was that in order to use the Cornell tags, the SG needed to be built with a raspberry pi instead of a beagle bone. Is that still the case?
It's just that the Cornell tags emit a more complicated signal than
the Lotek tags; their XCVR radio dongle decodes that signal into
an ID code, but to use an rtlsdr for the same purpose would require
doing that decoding in a software plugin, as we do for the much
simpler Lotek tag signals.
I real love that there are coming more suppliers of tags. That’s real great! And lovely that you are working hard on it for the Motus database.
Earlier, I understood that this tags can also run on 150.100 mHz, what is great for Europe. But do I understand it well that this tags can’t detect by Funcube+ or other type of dongles? And if you have 6 antennas on your SG and like to detect Lotek and Cornell tags (if they have the same frequency range), do I need to put than two USB dongles on one antenna? And if yes: is putting two receiver dongles physically possible, without loss of detection range?
(*) automatically extracting Cornell tag IDs from the signal would
require writing a plugin which, we haven't done. When testing, we
simply recorded raw signal from the funcube and examined it manually.
Yes.
A low-loss antenna splitter would send nearly 50% of the signal power to each
dongle, so each dongle's detection range would be ~ 70 % of that when
connected alone (i.e. splitting reduces detection range by ~ 30%)
