Sorry it took me a little while to get back, I had a couple of other things I had to chase up along the way. I’ve run the Cell modem troubleshooting | SensorGnome User Guide and the modem itself all checks out and is working fine (compilation of test results below). It’s just the GPS that’s still misbehaving.
(The initial step I ran, not included in the guide, was to list off the /dev/tty devices without any USB connections at all, and then with just the USB cable to the Sixfab HAT, to show the modified port list.)
Troubleshooting Results
gnome@SG-E3E4RPI4CED5:~ $ ls -las /dev/tty* … 0 crw-rw-rw- 1 root tty 4, 9 Nov 28 09:17 /dev/tty9 0 crw-rw-rw- 1 root dialout 204, 64 Nov 28 09:17 /dev/ttyAMA0 0 lrwxrwxrwx 1 root root 12 Nov 28 09:17 /dev/ttyGPS → /dev/ttyUSB1 0 crw-rw-rw- 1 root root 5, 3 Nov 28 09:17 /dev/ttyprintk 0 crw–w---- 1 root tty 4, 64 Nov 28 09:17 /dev/ttyS0
gnome@SG-E3E4RPI4CED5:~ $ ls -las /dev/tty* … 0 crw-rw-rw- 1 root tty 4, 7 Nov 28 09:17 /dev/tty7 0 crw-rw-rw- 1 root tty 4, 8 Nov 28 09:17 /dev/tty8 0 crw-rw-rw- 1 root tty 4, 9 Nov 28 09:17 /dev/tty9 0 crw-rw-rw- 1 root dialout 204, 64 Nov 28 09:17 /dev/ttyAMA0 0 lrwxrwxrwx 1 root root 12 Nov 28 09:17 /dev/ttyGPS → /dev/ttyUSB1 0 crw-rw-rw- 1 root root 5, 3 Nov 28 09:17 /dev/ttyprintk 0 crw–w---- 1 root tty 4, 64 Nov 28 09:17 /dev/ttyS0 0 crw-rw-rw- 1 root dialout 188, 0 Nov 28 09:17 /dev/ttyUSB0 0 crw-rw-rw- 1 root dialout 188, 1 Nov 28 09:17 /dev/ttyUSB1 0 crw-rw-rw- 1 root dialout 188, 2 Nov 28 09:17 /dev/ttyUSB2 0 crw-rw-rw- 1 root dialout 188, 3 Nov 28 09:17 /dev/ttyUSB3 0 crw-rw-rw- 1 root dialout 188, 4 Nov 28 09:17 /dev/ttyUSB4
gnome@SG-E3E4RPI4CED5:~ $ mmcli -L /org/freedesktop/ModemManager1/Modem/0 [Telit] LE910C4-AP
gnome@SG-E3E4RPI4CED5:~ $ mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0 | device id: fc9dd91daf3a558c4f3e01bd94e3abbfebe07f3a
Hardware | manufacturer: Telit | model: LE910C4-AP | firmware revision: 25.21.680 1 [Mar 04 2021 12:00:00] | carrier config: default | h/w revision: 1.20 | supported: gsm-umts, lte | current: gsm-umts, lte | equipment id: 357575100273804
System | device: /sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3 | drivers: option, qmi_wwan | plugin: telit | primary port: cdc-wdm0 | ports: cdc-wdm0 (qmi), ttyUSB0 (ignored), ttyUSB1 (gps), | ttyUSB2 (at), ttyUSB3 (at), ttyUSB4 (ignored), wwan0 (net)
Status | lock: sim-pin2 | unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (10), sim-puk2 (10) | state: connected | power state: on | access tech: lte | signal quality: 89% (recent)
Modes | supported: allowed: 3g; preferred: none | allowed: 4g; preferred: none | allowed: 3g, 4g; preferred: 4g | allowed: 3g, 4g; preferred: 3g | current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-1, utran-6, utran-5, utran-8, eutran-1, eutran-3, | eutran-5, eutran-8, eutran-9, eutran-18, eutran-19, eutran-26, | eutran-28, utran-19 | current: utran-1, utran-6, utran-5, utran-8, eutran-1, eutran-3, | eutran-5, eutran-8, eutran-9, eutran-18, eutran-19, eutran-26, | eutran-28, utran-19
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 357575100273804 | enabled locks: fixed-dialing | operator id: 50501 | operator name: Telstra Mobile | registration: roaming | packet service state: attached
3GPP EPS | ue mode of operation: csps-1 | initial bearer path: /org/freedesktop/ModemManager1/Bearer/0 | initial bearer apn: super | initial bearer ip type: ipv4v6
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0 | sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active) | slot 2: none
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/1
gnome@SG-E3E4RPI4CED5:~ $ ip route default via 192.168.1.1 dev wlan0 proto dhcp src 192.168.1.103 metric 3004 default via 100.80.233.125 dev wwan0 proto dhcp src 100.80.233.124 metric 10001 mtu 1500 100.80.233.120/29 dev wwan0 proto dhcp scope link src 100.80.233.124 metric 10001 mtu 1500 192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.103 metric 3004 192.168.7.0/25 dev ap0 proto dhcp scope link src 192.168.7.2 metric 3005
gnome@SG-E3E4RPI4CED5:~ $ ping -I wwan0 1.1.1.1 PING 1.1.1.1 (1.1.1.1) from 100.80.233.124 wwan0: 56(84) bytes of data. 64 bytes from 1.1.1.1: icmp_seq=1 ttl=54 time=525 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=54 time=404 ms 64 bytes from 1.1.1.1: icmp_seq=3 ttl=54 time=364 ms 64 bytes from 1.1.1.1: icmp_seq=4 ttl=54 time=405 ms
gnome@SG-E3E4RPI4CED5:~ $ mmcli -m 0 --location-status
Location | capabilities: 3gpp-lac-ci, gps-raw, gps-nmea, agps-msa, agps-msb | enabled: 3gpp-lac-ci, gps-nmea | signals: no
GPS | refresh rate: 30 seconds
gnome@SG-E3E4RPI4CED5:~ $ ls -las /dev/ttyGPS 0 lrwxrwxrwx 1 root root 12 Dec 6 05:14 /dev/ttyGPS → /dev/ttyUSB1
gnome@SG-E3E4RPI4CED5:~ $ gpsmon tcp://localhost:2947 Unknown device>
gnome@SG-E3E4RPI4CED5:~ $ gpsmon /dev/ttyGPS gpsmon:ERROR: SER: device open of /dev/ttyGPS failed: Device or resource busy - retrying read-only gpsmon:ERROR: SER: read-only device open of /dev/ttyGPS failed: Device or resource busy
gnome@SG-E3E4RPI4CED5:~ $ gpsmon /dev/ttyUSB1 gpsmon:ERROR: SER: device open of /dev/ttyUSB1 failed: Device or resource busy - retrying read-only gpsmon:ERROR: SER: read-only device open of /dev/ttyUSB1 failed: Device or resource busy
After that, I ended up going down the rabbit hole of Linux/ Debian boot sequencing and the intricacies of systemd, which if nothing else has been instructive from a systems administration and architecture viewpoint. Eventually I did find the gpsd service option file at /etc/default/gpsd, which I then tweaked to set the debug level: first -D 3, then -D 4, and restarted gpsd each time via systemctl with the following results:
gpsd Status With Debug
gnome@SG-E3E4RPI4CED5:~ $ sudo systemctl status gpsd.service ● gpsd.service - GPS (Global Positioning System) Daemon Loaded: loaded (/lib/systemd/system/gpsd.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2024-12-09 16:37:49 UTC; 6s ago TriggeredBy: ● gpsd.socket Process: 2691 ExecStart=/usr/sbin/gpsd $GPSD_OPTIONS $OPTIONS $DEVICES (code=exited, status=0/SUCCESS) Main PID: 2693 (gpsd) Tasks: 1 (limit: 1599) CPU: 47ms CGroup: /system.slice/gpsd.service └─2693 /usr/sbin/gpsd -n -r -D 3 /dev/ttyGPS /dev/pps0
Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: listening on port gpsd Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: stashing device /dev/ttyGPS at slot 0 Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: SER: opening GPS data source type 3 at ‘/dev/ttyGPS’ Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: SER: speed 9600, 8N1 Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: attempting USB device enumeration. Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: 1d6b:0003 (bus 2, device 1) Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: 1bc7:1201 (bus 1, device 3) Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: 2109:3431 (bus 1, device 2) Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: 1d6b:0002 (bus 1, device 1) Dec 09 16:37:49 SG-E3E4RPI4CED5 gpsd[2693]: gpsd:INFO: vendor/product match with 091e:0003 not found
[sudo] password for gnome: ● gpsd.service - GPS (Global Positioning System) Daemon Loaded: loaded (/lib/systemd/system/gpsd.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2024-12-09 16:06:49 UTC; 6min ago TriggeredBy: ● gpsd.socket Process: 1305 ExecStart=/usr/sbin/gpsd $GPSD_OPTIONS $OPTIONS $DEVICES (code=exited, status=0/SUCCESS) Main PID: 1306 (gpsd) Tasks: 1 (limit: 1599) CPU: 39ms CGroup: /system.slice/gpsd.service └─1306 /usr/sbin/gpsd -n -r -D 4 /dev/ttyGPS /dev/pps0
Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:PROG: Probing “Garmin USB binary” driver… Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: attempting USB device enumeration. Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: 1d6b:0003 (bus 2, device 1) Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: 1bc7:1201 (bus 1, device 3) Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: 2109:3431 (bus 1, device 2) Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: 1d6b:0002 (bus 1, device 1) Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:INFO: vendor/product match with 091e:0003 not found Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:PROG: Probe not found “Garmin USB binary” driver… Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:PROG: Probing “GeoStar” driver… Dec 09 16:06:49 SG-E3E4RPI4CED5 gpsd[1306]: gpsd:PROG: Sent GeoStar packet id 0xc1
Does any of that shed any light? I’m tempted to suspect no good of the “vendor/ product match not found” message, but on the other hand it is just an INFO level message.
I was going to mention a couple of other things about the external USB hub configurations, but it’s now very early in the morning so I will follow up in another post ![]()
Regards Andrew Hide
