I mistakenly created, and want to delete, a phantom station
I started to create a station, but stepped away before completing the process. When returning, I seem to have started fresh rather than adding to what I’d done before. Thus, I have created 2 stations, one is incompletely registered (#15589) and is “PENDING”, the second (#15596) is completely registered and is “ACTIVE”. I would appreciate guidance in how to delete the partially registered station #15589, please. Thank you, Ken
I also have a few in this state and would like to delete them. At a minimum, I would like them to not show in the beta as prominently.
I have 2 stations and need to add the BluMorph antennas that were recently installed.
  1. Does this mean I have to terminate the old deployments and begin again?
  2. What if I screw that entry up? Do I have to terminate and begin again every time i change something on the deployment details?
  3. The installer sends the info using (USB2, 3, 4 or 5) instead of a Port number. That’s confusing, so I’m not sure how to add the new antennas? The drop down menu doesn’t seem to have what I need?
  4. If nothing else changed, and only the BluMorph 2.5 GHz was added, do I need to end the current deployment? Or simply add antennas?
  5. Lastly: He sends the antenna height in feet; e.g. 31’ 6", 26’ 6", 21’ 6", 37’ 6". The conversion to meters is an estimate when entering it on the deployment configuration. What should the meters be?
