What is the format of the USB drive that one can used to down load wifi name and password. on CTT V3 . I keep getting errors. I checked and my json file on the json webpage and it tested ok. Software drive me nutz.
Glenn - can you clarify - it sounds like may be attempting to upload your WiFi credential to your SensorStation via the USB port as described in section 16.3 of the CTT SensorStation Guide? If so - Ive done this in the past using a usb driver formatted FAT-32. Its important for your usb drive to be 32Gb or less. If USB larger than 32Gb then it would need to be formatted “ExFat” but I have not tried to do one on a CTT station - I could try that and get back to you if thats an issue for you.
-Rich
Correction… newer installation manual from CTT covers this topic in Section 17.2 (not 16.3). and states USB drive formats FAT32 and MS-DOS are supported. So USB drives > 32GB that requre ExFat format likely may not work…
Glenn,
We recently created a YouTube video describing how we connect a Sensorstation to WiFi here at Bird Conservancy of the Rockies. https://www.youtube.com/watch?v=zYWCpyaXaXo&t=21s In the video, we used a program called Putty (https://putty.org/) but using the Windows Powershell program will work the same way. If you’re on a Mac, use Terminal.
Personally, I’ve never had great success using the thumb-drive method. Probably because of improper formatting!
Hope this helps!
Matt
Sorry for the late reply. FAT32 is the format of choice.
Cheers
David
