Has any one used any sdr beside the Funcube sdr on Sensor Station CTT Version 3.
Also with CTT Version 3 does the Funcube still be need to change the firm ware to 48 KC or can it run on196KC.
Hello Glenn,
Some of us have tried other SDRs with limited success. I think the consensus is that unless cost is really limiting, paying for the higher sampling rate and having the SDR originally designed for sensorgnome is worth the price. AFAIK, the 48KC upgrade is necessary.
Patrick Lorch
plorchgm@gmail.com
Quick confirmation: the 48 Khz firmware update for the FCD is absolutely required, it will not work with the std firmware.
