Error when trying to download receiver data
Potentially (probably!) a really simple solution to this…
I am trying to download the data associated with a single receiver. I am using code from the guide that looks like this:
proj.num ← “CTT-AD554C13AB19”
sql.motus ← tagme(projRecv = proj.num, new = TRUE, update = TRUE)
Of course when i enter tagme() it asks for my login name and password, but when i provide this (and i have double checked that I’m putting the correct thing in!) i get the error:
Error: Server returned error ‘Invalid parameters’
What are the invalid parameters? I assume not my login and password because i have used this to download project data and other receiver data. So the issue is the receiver number. Is it incorrect? Or is there literally NO data to provide? If this were the case, should it not specify that? i.e. tell me there are no files? If the receiver is working correctly, which i had hoped it was, then I would hope there is some data available. Even runlen<3…
Can someone give me any indication of what the specific issue is and how i can go about fixing it?
Thanks in advance!
Hi Lucy,
Are you sure data has been transmitted from that sensorstation to Motus? If there’s no data, I’ve gotten errors.
Other potential fixes include:
Option 1 (easy) do motusLogout() or close and start a new session. May work. Particularly if you reset your password recently.
Option 2: update the motus package and any other R packages.
Option 3: reinstall R. You would be surprised how many time this was by far the easiest option rather than fiddling with broken packages.
The information contained in this message and/or attachments is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any system and destroy any copies. Any views expressed in this message are those of the individual sender.
