ES File Explorer, which is the Android app I had previously used for remotely downloading Motus data from the RPi, was removed from the App Store for corruption (or some other reason). I’ve tried a few other options, but none seem to work with the sensorgnome. I can’t seem to get the FTP to connect. Has anyone found a workaround for this issue?
Best,
Jamie
Hi Jamie,
I’ve not given it a test yet, so be warned, but a quick search suggests the free Total Commander may fit the bill as a replacement fro ES File Explorer, though it will also require the sFTP or FTP plugin…
I don’t typically recommend something without trying it first, so maybe I’ll throw these on a Chromebook and give it a test and report back. Until then, proceed with caution unless others can confirm…
Adam
I just wanted to respond to this in case others were having the same issue. Total Commander did not work for me, but File Manager+ does. I’ve been using it this past week. It seems to work even better than ES did! Faster and more user-friendly.
