The Motus Server is currently impacted by processing backlogs.
This affects all Lotek tag data, as well as CTT data from manually uploaded SensorStations. CTT data from internet-connected SensorStations is largely unaffected.
For impacted receivers, the most recently processed data is from 2026-09-16
Last updated:2026-11-04
Overview
Motus detection data files are uploaded, processed, and are made available at Motus.org and the R Package via various pathways. Processing and data transfer backlogs may affect data and upload types in different ways. Information on current processing times will be posted to this page weekly.
We are actively working on refactoring the legacy Motus data pipeline to eliminate processing delays. Full details available here: Update and upcoming improvements regarding Motus processing
For more information about the data processing pipeline, please visit How Data are Processed | Motus Docs |
More info
SensorGnome receivers
All data uploaded from SensorGnomes, either manually or via the internet, passes through the Motus Server and is affected by the backlog. This includes both Lotek and CTT tag data.
You can check on the current status of internet-connected V2 SensorGnomes at SGhub.
SensorStation receivers
CTT tag data from Internet-connected SensorStations does not pass through the Motus Server and is unaffected by current backlogs
Manually uploaded Lotek and CTT tag data passes through the Motus Server and is affected by the backlog.
You can check on the current status of internet-connected SensorStations at the CTT Fleet Portal.
Lotek SRX receivers
All SRX data passes through the Motus Server and is affected by the current backlog.
