Connecting to 5 GHz WiFi with Raspberry Pi
Hi everyone,
Has anyone found a way to get a SensorGnome to connect to wifi networks on the 5 GHz bandwidth? It seems like where I work (mostly in Ontario, Canada but currently in Belize), the 2.4GHz connections are becoming less available to get towers online with wifi.
Thanks,
Derek Morningstar, M.Sc., PWS
Myotistar
myotistar@gmail.com
www.myotistar.ca
(226) GOT-BATS
Derek,
The onboard WiFi on a Raspberry Pi 3 does not support 5GHz WiFi, but you can use a USB dongle that supports 5GHz and connect that way.
Source: https://forums.raspberrypi.com/viewtopic.php?t=192541#:~:text=The%20WIFI%20on%20RPi%203B,a%20USB%20WIFI%20’dongle’.
Matt
@myotistar a little late, but Raspberry Pi 4 can connect to 5 GHz WiFi.
