We recently installed a Motus station with a CTT SensorStation at the U of Alberta campus and want to connect the SensorStation to the University Wifi. However, U of A requires both a username and password to connect to the network, but the software on the rasperypi seems to only accept a network name and password, not a username. Does anyone know how to update the software on the Raspberry Pi so that a username can be added to the wifi credentials?
You may be referring to a âcaptive portalâ where the network requires you to log in via a browser to be authenticated. I donât think the SensorStation or SensorGnome support this natively, but there may be workarounds. @user80 and @TvE may be able to elaborate on the details.
I donât think the network necessarily needs to be authenticated via a browser (e.g. like you often have to do with free wifi at airports and hotels). I just need to be able to provide 3 values to the wifi credentials: network name, username, and password. For most home wifi networks, you just need a network name and password, but for corporate wifi networks, you often need a username as well.
Do you know what the authentication method in use in your network is called? (Sorry, I lost touch with enterprise wifi authâŚ)
In general, youâll find the wifi client authentication in /etc/wpa_supplicant/wpa_supplicant.conf (I also see it on my SSv3 but I donât know whether it uses it or overrides it somehow). You can find info on that file if you search for wpa_supplicant, itâs a standard linux thing. You should be able to edit it and restart the wifi (systemctl restart wpa_supplicant âŚ?). If you need help, LMK.
For reference, this is what it looks like when I configure for my WPA2/PSK network:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=us
network={
ssid="iot-net"
psk=02585a8fb000000000000000766abe50d1000000000af31dcd255
key_mgmt=WPA-PSK
Hi Thorston. Thanks for your response. I finally found the info I need for the wpa_supplicant.conf file in order to connect to the U of Alberta network. U of A IT provided the following:
network={ ssid=âUWSâ key_mgmt=WPA-EAP eap=PEAP identity=âyour_CCID usernameâ password=âyour_CCID passwordâ phase2=âauth=MSCHAPV2â id_str=âUniversity_of_Albertaâ }
My question is, how do I edit the supplicant file using command line in Windows Powershell? The SensorStation instructions explain how to modify the wifi credentials via âsudo raspi-configâ, but this leads to a menu that only allows you to update SSID and passphrase.
Do you know the syntax to manually edit the wpa_supplicant.config file from the commad line?
my recommendation would be to ssh into the SS and use the nano editor to edit the file (sudo nano /etc/wpa_supplicant/wpa_supplicant.conf).
Great, that works to update the wpa_supplicant.conf file! Just to confirm, after Iâve updated the file, do I need to restart the wifi using systemctl restart wpa_supplicant as you mention above? For now Iâm just experimenting with the SensorStation at home, but Iâll be installing it a University tomorrow. Thanks!
Yes, you have to restart the wifi, it does not watch the file.
