All:
Currently Lotek makes the lightest tags that can be detected on the majority of Motus stations- so for anyone wanting to tag species that require a tag lighter than 0.35g, that's the choice. In terms of frequencies, there is definitely validity in multi-mode stations- that was the rationale behind us creating the SensorStation with so many potential inputs: eventually a new frequency would come along and provide an advantage over the others, for specific applications; or a new feature would be requested and we wouldn't want Motus collaborators feeling like they had to wholesale change over their station. The shorthand for this was "future proofing".
For instance, we have a client in Peru who has a LoRa network for communicating when traps are triggered, so we were able to adapt one of their LoRa radios to one of the 5 pads typically reserved for the 434MHz radios. In other cases researchers required six (6) or more 434MHz antennas for doing localization ala the ARTS (Automated Radio Telemetry System) setup, so with the plethora of USB ports these could be added via dongles.
Now we've launched a new line of tags on a new frequency, 2.4GHz, which, with a simple plugin adapter, can be added to existing SensorStations- and (I can hear you holding your breath from here) will require additional antennas. We installed the first in Mexico last week, using four 2.4GHz panel antennas which each have a footprint of 10cm x 10cm x 8.5cm- think of really small cubes. These four antennas can pick up tags up to two or more KM (possibly farther, we've only tested out to 2KM so far), but each provides a 90 degree pickup pattern, so with 4 we get full 360 degree coverage around the station. These tags weigh only 0.06g, but are solar-only, so no good for bats yet (the battery-only version is coming out in the next couple of months and weighs ~0.13g and beeps for 46 days at a 3 sec interval), or nocturnally migrating birds (although the hybrid version si coming out mid-2024 and will weigh ~0.15-0.2g) where nocturnal detection is important- but it makes sense to think about adding this frequency to all Motus towers eventually, as this will allow for a massive expansion in species which can be tracked- from insects (the tags are already being deployed on Monarch butterflies and Asian hornets), small birds (we deployed 11 on 5 species of hummingbird last week in Mexico, the smallest being 3.1g and in all cases the full tag and harness was < 3% of the bird's mass), and eventually even the smallest bats.
So while I absolutely understand the real costs of multiple frequencies (I manage my own Motus stations in Cape May, NJ), it makes sense to think about how we can best support all frequencies with the smallest footprint. For instance, when 13 Gulf Coast stations were upgraded to SensorStations a few years ago, there wasn't enough funding to install a full compliment of 434MHz yagi antennas- so only a single omni was added at the time. Those omnis detected a bunch of birds moving between across the gulf in both spring and fall! Since then they've been incrementally upgraded with additional yagis as funding allows.
Just my 3 cents.
David
David A. La Puma, PhD (He/Him) • Vice President, Global Market Development
celltracktech.com • (609) 889-0305 x104 • Book Time With Me
“If we did all of the things we are capable of, we would astound ourselves.” - Thomas Edison
