Advisory against CLEAR stretch magic for gluing
Hi folks,
Just wanted to send out a quick note advising against the use of clear stretch magic when gluing harnesses to tags. There is something with the plastic that doesn’t bind well to all super glue brands. It used to work well, but something may have changed. It’s fine for other harness-types. BLACK stretch magic still works well, but it’s important to test well in advance of deployment.
Another Pro Tip - lightly scratching the surface of the tag with sandpaper or another abrasive where you’re applying the harness will also ensure a tighter bond.
Cheers
Stu
[2dca1855-ad67-41aa-b8e7-607fbece5560]
