I’m new to Motus and trying to troubleshoot an issue collaborators had with some antennas not functioning on some stations. I think I want the “activity” table and to look at the numGPSfix field, but I can’t figure out how to determine the exact time or day when numGPSfix comes back as NA.
I can match the batchID’s to data in other tables to get a start and end date/time for a batch, but I don’t know I can assume an antenna was or was not functioning during the period within a batch.
Is there a way to get a more specific time stamp for each row in the activity table? Is there a way to use the hourBin field with the batchID start or stop time to do this?
Hi! I think you can can back-calculate the UTC timestamp from the hourBin and from that UTC timestamp convert it to local time. If you’re using R, it would be something like:
library(dplyr)
library(lubridate)
t <- tagme(XXX, new = FALSE, update = FALSE)
problems <- tbl(t, "activity") |>
# This select is not strictly necessary, only to remove columns you don't need
select(-contains("run")) |>
filter(is.na(numGPSfix)) |> # Your filter of interest
collect() |> # Times need to be collected first
mutate(ts = hourBin * 3600, # Back convert to timestamp (ts)
time = as_datetime(ts), # Convert to time
time_local = with_tz(time, tzone = "America/Vancouver") # Convert to local time (replace this with your local time)
problems
Note that the timezone in the last step needs to be one of something from OlsonNames()
Does this help with your problem?
Yup, I wasn’t aware the conversion for hourBin! Thanks!
