Please be sure to read FUNcube sample rate dropping and disconnecting - FIXED - #2 by TvE and the post after it. The 4 FCD on one hub will only work if the hub is a Multi-TT hub. If you have an rPi 4 the hub should be plugged into the top USB3 (blue) port.
